Guys, I need some help with an issue with my trailer. My Boatmate trailer is locking up when in reverse even on flat land. It will only go in reverse on a downhill like a ramp. Does anyone have any advice? Thanks
5 pin or 7 pin connector to truck? Trailer will lock if a reverse signal is not received from truck.
It's a 5 pin. I have tried the nickel trick that I read about and It worked. I will also check the above! Thanks
