Quote:
The RXA-T2 is a 2 channel high power amplifier with 2,400 Watts peak output, 1,200 Watts RMS output (2 x 600 @ 2 Ohms) and 800 Watts RMS (2x 400 @ 4 Ohms). You can also bridge the amplifier and get 1 x 1,200 Watts RMS @ 4 Ohms. The CEA-2006 compliant rating is 200 x2 @ 4 Ohms and 300 x 2 @ 2 ohms <1% THD. Most brands do not use CEA compliant ratings because quite simply they do not want you to be able to compare their amps to others on the market. Over here at Rockville, we want you to be able to compare our amps to any brand on the market. For this reason we are supplying you with multiple ratings. The CEA compliant rating should be used when matching up or comparing this amplifier to other CEA compliant brands such as Kicker, Rockford Fosgate, Alpine, etc. We also supply an RMS rating which should be used when comparing with great brands that are not CEA compliant such as Hifonics, Earthquake, Powerbass, etc. The peak rating is simply what the amplifier can hit for a split-second at the highest point of a song. This rating from any brand is not really important. RMS and CEA ratings truly are the most important.
