According to Rick T's post, I guess he would know, that is true. I wonder if that dealer just took a SWAG at it or something. A little scary if so. Perhaps the dealers need to be on the forum to read what Rick T. puts on here!
Don't forget the supra s type tower will be an option for 2015
2013 Moomba LSV
Just for Clarification sake
The New Engine for Moomba is the 400 6.2L Ford Raptor. The 400 signifies a couple of things.
The HP is close to 400, but will be rated at 386.
The Torgue is at 404 ft/pounds which is where you feel the real power of this engine.
The Ford Name is not meant to only discuss HP but more importantly Torque. Though both are very near the 400 number and thus the name.
The Sbend Tower is an option on 2015 Mojo, only.
Rick T, thank you for that clarification.
Can you clarify/comment on the new mojo hull dimensions or is that an August 1 topic?
Some comments have have been made about beam change to 100" and also some comments about 23' or 22.6 etc....
Your Larger dimensions are correct from what I have heard. Looking at the picture though I only see it in the nose. The nose looks longer now, and it looks to have a more pronounced lip at the rub rail from where the lower hull meets.
Interior wise it has some subtle line differences such as on the rear seats. Dash appears to be rounded on top and not as boxy. Tower looks like it was slightly shifted back but that might be optical from the picture.
Though I would try something and it looks like some of the data and landing pages on the 15's have be put into the Boat Configurator. So if you open the Configurator and then change the last two numbers in the address bar to:
21
22
23
24
you will get the Moombas
15
19
20
you will get the 15 Supras
I was messing with supra page (20) and I seen option stating SE and SG I have not heard of anything about an new supra SG (I wonder if the SG is going to be the 242)
