Just bought a 2004 Moomba Mobius XLV. Steering, bilge, and water intrusion issues.
Hi, new to the forum and to inboard boats altogether.
Had a few questions about my used 2004 XLV that I just bought. Runs great, good compression, just serviced and we are really enjoying it with a few exceptions....and please forgive my ignorance....still figuring this thing out.
1. Why are there two bilge hose outlets on the side?
2. We ran into an issue on the lake with the bilge pump. We had to head back to shore after the pump quit working. It was coming on every 30 minutes or so, which seems like a lot compared to my old Sea Ray that I had. Just bought a replacement because I think the old one burned out. Water got up to the upper parts of the V drive but well below the engine. Do I need to replace the fluids? I am going to check all obvious places for leaks, exhaust clamps, drive shaft bearing, etc. One thing I need to figure out is the location of the ballast bag valves. the previous owner took the bags out and I think one may be open hence the extra bilge water. Any other areas to check? Also, I only know of one drain plug on the transom and no others.
3. Anyone ever run a backup bilge pump? Maybe connect to backup battery and spare alternate switch? Overkill?
4. Steering is tight. Difficult to turn at times. I've read up on forums about replacing the cable but I was wondering if I could try lubing any zerk fittings or anything like that first. Don't know where to start.
5. Anyone know where I can get a service manual? I have the owner's manual, but I was hoping to get something like a Chilton's or Hayes type manual.
6. Anything else I need to know about Moombas? So far my first impression is great. Love our new boat.
Thanks in advance for your responses!
Your bilge shouldn't be coming on unless you're taking water over the bow or something of that nature. If your just driving around then I don't see any reason why the bilge would be running. Did you out both drain plugs in?
The multiple outlets are likely for ballast system vents.
If you're coming from an I/O like I did, the steering stiffness is tough to adjust to.
There are many more experienced inboard boaters and XLV owners who can probably provide more insight.
Just bought a 2004 Moomba Mobius XLV. Steering, bilge, and water intrusion is...
Quote:
Originally Posted by
jmvotto
I am pretty sure the center plug is only for direct drives... check page 23 of the manual
I don't know for sure, just something for him to check. My Mojo has 2 drain plugs.
I thought they all had 2... I usually just pull my center one when it's not in the water and leave the transom one in place.
