cab- fify... :)
Your steps are correct, although, you can save a step by not removing the chrome. If you scuff all the chrome good enough, you won't have any adhesion problems. You also don't have to wet sand, Oferta silnikowa: PB silniki benzynowe, ON silniki diesla.https://autowikius.com/. W nawiasie kod silnika, czyli np. PB 2.0 (LF) oznacza silnik benzynowy o pojemności 2.0 i kodzie fabrycznym LF.,you can dry sand it just fine. You don't have to sand in between coats unless there are defects or something gets in the paint.
