I don't mind the fusion but I like the display better on the JL unit. I think OCD is also partially responsible though lol
i decided to stay with the Fusion head unit to save some money. The new setup sounds amazing but at low volume i can hear a buzzing noise. That noise wasn't present when I picked up the boat. I had a tech from the install shop check it out and he did a ton of trouble shooting and came to the conclusion that there is an issue with the Fusion HU. Something about only having 2 RCA out puts and running one for the sub and then 8 (2 tower and 6 cabin) on the other. I'm not really sure what the hell he's talking about. Maybe you can help me out?
There are a number of things that can cause noise. When you here the noise, what the noise sounds like and which speakers omit the noise all narrow down the root cause. Sounds like the system has 3 amp all split off the single RCA pair output? This will cause the gains to be higher then desired, in order for the amps to make their rated wattage. This can invite noise. How is the head unit wired, is another factor.
