5 Attachment(s)
Hull through exhaust problem
Noticed my bilge was filling with water when I was sitting and thought it was the packing. Replaced with gotex, still more leaking. Diving in more I found water spilling in from the hull through exhaust . Read the forums and seen all the destruction from this poor designed plastic piece and sure enough mine was no exception! Melted , barely screwed into the transom. I unbolted and it literally fell straight to the ground . Noticed after cleaning the Delaminated transom. The plan - get my machinist friend to make 2 new aluminum hull though exhaust flanges with better hole placement and tighter tolerances. As for the transom I’m gonna let it air dray and then epoxy and clamp back together . Any more ideas or thoughts would be greatly appreciated ! - Eric
