Respectfully withdrawn ex, my bad. Glad to hear you guys are getting the situation ironed out!
Have you made contact with anything in the water with the rudder? Make sure that there are no obstruction under the engine as well. I left a rag in there one time and it got caught up in the rudder arm inside the boat. Good luck.
Thx...I think its due to the boat sitting for almost 3 months...I am going to try and have the steering cable inspected
That may be a good idea to have the steering cable checked. Mine went up after about 200+ hours of use. Got extremly hard to steer, to the point that i was sore driving. Upon replacement, was nice and easy to steer.
Thx...I will havew the new owner check that...I sold the boat so I gave the guy about an extra 900$ to fix the problem. I guess I should have checked it before , maybe will end up being cheaper
I'll still swear by ' a pound of prevention is worth an ounce of cure ' . Grease your rudder shaft and the cable ends. Don't goop it on, just enough to form a barrier to keep moisture out. After almost 2 years and over a hunnerd hrs she feels as good as the day I brought her home
(p.s. tell your wife that occasionally too)
B
