Anyone have the new 2023 software file? I have updated my boat last year for 2022 and have the instructions on how to do it.
So by end of summer i finally figured out my boat was probably around 13 deg of pitch, with all water ballast and 1400lb of lead. LOL
Pulled all led out recalibrated the inclinometer and put it all back in and voila!
first time in two years I can have all bags full and hit all the settings on autowake.
This was no small feat since my boat was on our buoy, had small zodiac with all the lead and other belongings in it until i could zero it.
Having second thoughts about upgrading the software to the 2023, would i have to zero the inclinometer again...
Thanks for everyone's help!!!, The wife can take the boat out now and figure take the kids surfing when im not around:cool:
Somewhat related to this; we pull our batteries out and store them inside in the winter. I suspect (but don't know for sure) that doing this means I need to do recalibrate the inclonometer when I reconnect the batteries every season. Anyone can confirm?
Just as an FYI, you can turn off the battery switch, but there are still some loads still on the battery. I am not sure if the computer memory is drawing power from the main battery (I suspect it isn't) but your bilge pump will still operate even with the battery switch off.
Anything that is directly wired to the battery such as your bilge, pretty sure that would be the only thing wired direct.
