After the summerized my '18 Craz I realized my coolent was at the lowline. Is it normal for this boat to burn through coolant?
I noticed the same thing with mine. It was actually below the low line cold on mine. So I added some when I got the boat out from winter storage. I have only had it out twice since then, and I need to check it again.
Same with my 2016 SE. I have noticed it just below the low level line a twice last year and again this year. Only need to add a little bit, but I'm wondering where it's going...?
Sent from my SM-G965U using Tapatalk
Mine uses half the overflow tank in 20-25 hours.
It should not, and I suspect a slow leak.
I plan to chase the lines from the cooling system and tighten clamps, however, the Indmar raptors use otiker clamps which you need a tool to pinch them tighter.
Make sure you use propylene glycol antifreeze.
Peak Sierra and Preston low tox are half the price as Indmar.
I wonder if these motors consume coolant. Last year my 2016 Craz had a overheated engine message pop up. I took her to the dealer and all it was is she was low on coolant. The dealer said there were no leaks found anywhere. I asked where the coolant went and they gave me a shoulder shrug. I haven’t added coolant to my cars ever! Any other comments?
Wow! I have a 2016 Craz as well and my coolant has never moved. Considering I have the heater I guess I am lucky!
Mystery solved....at least on my boat. I was prepping the boat to go out this evening and saw a small puddle of antifreeze under the passenger side seat. I traced the stream back to the heater. Sure enough, neither hose clamp was tight and I had a small drip coming from the bottom hose. Hopefully that is my issue!
I have a 2015 mondo. I always had a coolant leak every spring after it being winterized. I had tightened up every hose clamp. This spring i bought an adaptor of the snap-on truck to screw onto overflow tank and pressurize system. I found my leak was on the pump that circulates coolant up to the heater. Was at the joint where the pump met the motor.
