If you're having to dump your bilge from cup holder can condensation you are drinking WAY too slow....[emoji1787]
[emoji217][emoji481]
:D :D :D Now that is funny!!!!
Mainly the issue was from washing the boat and cockpit. The Yamaha storage compartments were all carpet and not the rubber lined like the Moomba. So carpet could get soaked real quick. I plugged mine soon after I bought it and never had to worry over it again.
Did you tie into your court lights for the cupholders and speaker lights?
I did, I removed the 2 courtesy lights, drilled them out from the backside (giggity) and glued in single rgb led’s.
I don’t believe I took any pics of the process but these are the single led’s I used:
XSPC Single 2x5x5mm RGB LED (4-Pin) https://www.amazon.com/dp/B0735J8PCJ...p_mob_ap_share
What was the process to tie the cupholders into the court lights wiring ?
I just used the courtesy lights switch to power the wetsounds rgb controller. If you aren’t going rgb you can just tap into the positive and negative wire going to the courtesy lights and wire the cup holders directly off that.
I'm doing just blue - gotta figure out which wire is the courtesy lights - i glanced up under the console and it was hard to tell what was what. Thanks for your help - you've done a great job with your boat.
You can just find the wiring right at the back of the courtesy light, tap into it then daisy chain to the new LEDs. That's what I did. Don't have to mess with anything under the dash if you're not doing RGB. I tapped into the wiring on each side of the boat. Pretty simple. I also left my courtesy lights w/o power since I never use them, and I didn't want white lights going along with my blue LEDs.
So would these be the updated bags? I forgot to check my build date on the boat.
Attachment 28290
