The factory speedometer on my '13 LSV doesn't work. It moves a little but for the most part its stuck around 10 mph. The paddle wheel is free? The temp gauge and the other gauge is workig fine. Any suggestions?
Does the 13 lsv have a digital speedometer and is it working?
The digital is working
Any update on the issue? I have the exact same issue with my 13 LSV, also my RPM gauge stays at 1000 as well.
You will have to replace the gauges.
Last year my RPM did the same and they had to replace it.
This year my Temp stays on 160 so I have to assume it will be replaced as well since my boat is not having issues ahs my sending unit is sending a signal.
