3 Attachment(s)
Another way too Drain Oil
During the winterzation i found another way to drin the oil other then the hand pump that pepople have been using. It also costs less for the setup. It only took about 1 min to drain all the oil out of the block.
Parts are a hose fitting and coupler that attaches to the oil drain hose. I think it was a 3/8's and is showen in the first pic. The second is a washer water hose that i shoved threw the plug hole so everything was down hill. The second pic is of the fitting on the hose and the drill pump to the jug. The third was a drill pump. Showen in the last photo. Total cost was about $20.
