Originally Posted by
EarmarkMarine
Al,
I don't consider faster charge time the issue. Its irrelevant mostly.
As you discharge a battery, the sulphates leave the solution and bond to the surface of the lead plates. As you recharge, the sulfates return to the solution for a concentrated sulfuric acid. When you undercharge or leave the battery discharged for long durations, the sulfates tend to bond permanently. Once the sulfates are permanently attached to the plates the battery may heat up, take a surface charge but won't accept a deep and lasting charge. Thus, a shortened playtime at rest and shortened overall lifespan.
It takes a prescribed amount of current (10 to 13 percent of amp/hours) to chemically excite a battery in order to properly desulphate and condition.
Earmark Marine
