I've had my boat a whole 4 days now and I've noticed my fuel gauge is off. First day I started with 3/4 full tank ran it down to about 1/4 tank. Filled up from 1/4 tank and took 24.xx gallons. Today I took the boat out for several hours just cruising, not pulling yet, and was cruising at 30mph when I noticed I was just below 1/4. Found a cove to chill for a bit and when idling in the fuel gauge is basically on "E" (3 of us in the boat, no ballast filled). Went to the gas station to fill up and only took 25.xx gallons to fill up. This doesn't make sense. To be on "E" and to full it only took 25.xx gallons in a 40 gallon tank. That's basically a 15 gallon error. I would assume you should trust your fuel gauge with the boat still or idling w/no wake.
