1 Attachment(s)
So, my swim platform came off yesterday
Like several other posters, I've been annoyed and concerned by the amount of play in my swim platform. I've also noticed the number of posts about swim platform problems so I figured it was bound to happen to me some day.
Yesterday as someone was climbing onto the swim platform it came totally off underneath them. In the process one platform mount came off with the platform and all the screws ripped out of the other mount, leaving it on the boat. I figure either a) a mount pin came out and one side of the platform rode up, causing it to put unbearable pressure on the other side, ripping out the screws or b) the pin on one mount just sheared off. I'm guessing based on the strength of the materials the pin had to come out on it's own. At first I was worried that our surfing setup (see my post about boat attitude) had caused undue stress on the platform. However, I surfed once more at the end of the day with the platform gone and I could see that the water wouldn't push against the platform if it was present.
A couple of the screws holding the mount plates are not super-tight, but none of them have any play in them what-so-ever. I also noticed that some screws on both platform mounts have non-stainless screws going into them, which have rusted. Based on the fact that these are flat-slotted wood screws and many of the screws had gunk on them, I have to assume that the former owner of the boat replaced some screws at some point (maybe after they stripped) with non-stainless screws and put in some epoxy or something that didn't hold.
Has anyone else had this happen to them? Can anyone vouch that the screws from the mounts to the platform are all the same stainless phillips screws from the factory? Finally, are there any methods of keeping the platform more solidly mounted? I'm not too concerned about quick release right now because I don't need to take my platform off ever. Finally, I noticed that the bottom of the mounts are both bulging down somewhat from the force on them. I think stopping the play in the platform will stop this from getting worse.
I'm tempted to replace it with a teak platform, but I kind of like the firberglass one and I generally like to keep my boat factory. However, I'm definitely not going to replace the factory pin. I've already bought a regular wire lock pin (see pic) from Home Depot and I'm looking for a stainless version. However, I've had trouble so far finding a stainless wire lock, so I may end up with a stainless clevis, which seems pretty easy to find.
Currently, my idea of fixing is this (after input from my car fixing buddy):
Fill in the screw holes with fiberglass resin
Put in all new stainless screws once the fiberglass sets up
Use Loc-tite red on the screws
Replace both pins with wire lock pins or similar
I'm also going to see about getting slightly large pins that will fill in the hole completely so I don't have play on the platform.
2 Part, 2 Ton Clear Epoxy
Hello,
I've had the same problem with my swim step ('07 Mobius XLV). Tightening/replacing the screws became a regular maintenance item. Finally, I came up with the bright idea of mounting the brackets to the swim step with 2 part, 2 ton clear epoxy (Home Depot stocks it) and my troubles are over.
Steps to success:
1. Remove the screws and brackets
2. Clean the mounting surfaces of the swim step and brackets
3. Apply the epoxy to the entire mounting surface of the brackets
4. Apply a small amount of epoxy to each screw hole on the swim step
5. Line up screw holes and screw the screws (sounds funny, huh)
6. Done!!! (Let it dry for a few hours, of course)
NOTE: You will still have the play issue due to the poor mounting pin design. However, this thread also has brilliant ideas to reduce/remove the play.
bhaastyle
