Just thought I'd post a few pictures of my ongoing stereo upgrade.
Here is the end goal, which should be done by this Friday (once all the goodies arrive in the mail).
http://farm2.static.flickr.com/1356/...5705489b44.jpg
I'm mounting the amps behind the passenger seat, against the inside of the hull. To do this, I first made a pattern for my amp rack out of cardboard. I then positioned it against the hull and marked 4 points that will secure the amp rack. I chopped down some 2x4's and installed bolts to use as mounting posts.
I then traced the outline of the 2x4 mounting plates onto the carpet.
http://farm2.static.flickr.com/1233/...5239ebddd2.jpg
I used a blade to cut the carpet so I could glue the mounting plates to the fiberglass.
http://farm2.static.flickr.com/1366/...137f0bc7d5.jpg
Then used some epoxy and a lot of shoulder-cramping arm-deadening force to hold it in place while it set up. Here is the end result.
http://farm2.static.flickr.com/1312/...fefcab41eb.jpg
Note that if the surface is not totally flat, you should contour the back of the 2x4 block to match. This will ensure a good bond.
Here is my first version of the amp rack, two Fosgate amps.
http://farm2.static.flickr.com/1223/...caa56cb36e.jpg
I've decided to upgrade these to Phoenix Gold Octane R amps. A 5ch 900w amp to drive the in-cabin speakers and single 10" sub. Then a 4ch 800w amp for the tower speakers.
I'm wiring the boat will all Monster Cable interconnects, speaker wire, and power cable. I decided to pre-cut and tape all the cables together to simplify the wiring. Here's some of the materials.
http://farm2.static.flickr.com/1234/...1aee87da67.jpg
After measuring and cutting the speaker wire, and adding a few lines of smaller-gauge wire for control signals, I taped it all together with some good 3M electrical tape.
http://farm2.static.flickr.com/1039/...afc7767376.jpg
I then ran the cabling around the hull, securing it to the underside of the gunwale using pre-existing mounting straps and cable ties. You might want to wrap your arms in rags, or wear a long sleeve shirt, or you'll have rashy arms for days!!
I also added a Optima yellow-top to the system. I found some great pre-made battery cables at the local auto store. They come in various lengths and make the install painless. I've set up the dual-batteries on a Perko switch. Using the same techniques as above, I made a backing plate for the switch and epoxied it to the sidewall behind the passenger seating.
That's it for now ... more to come.
