I am looking to rename (replace) my ACC switch label for "Stereo" and "Aft Lighting" but can't seem to find anyone who makes custom labels for toggle switches and I don't want to replace everything to rocker switches. Thanks for any help.
Same, I would like to re-name my ACC switches as I have something on them as well. If you find an option please let me know!
Have you checked the backside of the existing plates? Normally some options there from the factory.
I have not and didn't know that may be an option! I will check next time I have the boat out.
I remember a post on here from a year or so ago about someone getting customs made. Seems like he had them say "cannons"" "Missiles", "Machine Guns", "Ejection" etc... like a James Bond setup. I cant exactly remember when it was.
Search for the Murder Max Mods thread starting on post 70
https://uploads.tapatalk-cdn.com/202...d6f89a89db.png
Awesome find! That was exactly what I was remembering!!
I've seen those but my Type A personality needs it to match the others! Thanks for the suggestion and will keep it in mind if I can't get the perfect match.
I had a few done last year and they turned out great. Like was said above, take off the ones on there and the back side may be blank. I found 1 or 2 blanks and then added to an existing one. I found a local "trophy shop" and they did the engravings. They were able to match it perfectly.
Ahh yeah! A trophy shop, jewelry shop, or probably any sign store could probably make those easy.
Great suggestion! May be the route I go with.
Following advice from 996scott- I removed the ACC plates to find the backside was already labeled Underwater Lights! Took about 30 seconds of work and have what I was looking for. I took the other plate to a trophy shop and for less than 10 bucks they are engraving Stereo on it. Project is done!
Great news, glad it worked.
