2 Attachment(s)
Flow/Surf plates calibration?
Hello Everyone,
While surfing this past Saturday, i noticed great inconsistencies in the surf wave from time to time. I knew it wasn’t lake depth as that is a constant 15-20ft. Something was wrong with the surf system. The wave would be perfect one minute and completely wash out the next.
So, i turned off autowake to try and figure out some settings of my own and i noticed that the surf plates were not correctly setting. The desired setting was at 60 but the plate was at 50. No matter what setting i chose from 0 to 100 it was off by 10. I took video that ill try and post so that you can see what i mean. I also noticed that once the boat was out of the water, with both surf plates set at 0, the starboard side surf plate was maybe 10-15 degrees higher than the port surf plate.
I went through the menu and found the “return to zero” flow plate setting and i pressed it a number of times, heard the surf plates actuating, but no matter what it is off by 10 on both sides.
