The trailer and boat weight of a 2019 SA seems to be 7050 lbs.
A Range Rover sport towing max is 7600lbs.
Is that to close to the max?
Have any of you towed your boat with a ranger rover sport, if so how was it?
How far are you towing? How frequent? What kind of terrain?
Long trips - Probably not going to be happy
Once a week, 10 miles to the lake - no problem.
Mountain passes and steep boat ramps will be your worst enemy.
Remember 7050Lbs is not full of gear, lead, coolers, etc. Also I had ~200#of water in my ballast after my last lake trip that I did not even know was there until I winterized yesterday.
My 20 sl450 weighed 9050 lbs full of fuel and with 900lbs lead scattered throughout. 700lbs was the tongue weight with a tandem axle trailer. I pulled it 5000 miles this summer with a 20 gmc1500 with the 3.0 Duramax. Max towing weight is 9300lbs with my truck. I had zero issues running 80ish on the interstate.
I’d say you should be fine if your not hauling any lead.
I'd take a look at the hitch on that vehicle as well. The max towing capacity of the vehicle isn't always going to match the tongue weight capacity of the hitch. There's usually some kind of sticker on the hitch showing the capacity of that.
For heavy boats and steep or slippery ramps, 4x4 is necessary in my book.
I initially towed ours with a Jeep GC SRT. Capacity similar to your Rover.
Jeeps power was fine. No major complaints. However, I did not like it one bit. I felt every nudge and was scared to go above 45. I felt like if I made a small mistake the boat and trailer would take me with.
Decided on a ½ ton truck I got used with a lot of miles just for towing and it’s night and day difference.
Wife and I are considering a ¾ next season and sell my jeep and truck.
Go get the boat weighed. My 2016 craz and trailer was just under 7k lbs on a CAT scale. I dont think the weights in the advertising material account for many options on the boat.
Secondly, look at the loading sticker by the drivers side door for your car, that will tell you the true amount you can haul. You are more than likely overloaded with just the boat. Add people or gear, you are almost certainly overloaded.
Svien,
I caution against launching with a Range Rover. Our 15 HSE sucked water into the compressor when launching our first boat, due to a leaking strut. This set off a whole cascade of problems that took several years and a lot of money to work.
Making my new SA build come true!!!
Great information, thank you all.
One consideration I did not originally factor was the wear on brakes and RRs brake replacements are rip off expensive. So I’m looking for a truck but will wait a bit to see if the insanity in the second market eases.
