What is everyone using and what are your experiences with them?
There's a lot of info out there on the webs, but it can be hard to decipher between marketing and actual experience.
The boat bling stuff works well for hard water spots on the exterior. The vinyl sauce is good for cleaning but having to redo the work to add UV protectant sucks. I hate doing the job twice.
My detailer used Lithium products when he was buffing and cleaning up everything. The interior stuff is called Inner Space and cleans, conditions, and protects against UV all in 1. The exterior is Color Rush and is a ceramic quick detailer and worked great to clean and polish but didn't remove water spots. After using the whole bottle this season, now using boat bling hot sauce the gel is silk and cleans super easy.
I've got a bottle of hot sauce and it did help with water spots. Worked best with a buffer. Does it have much water repellant property? How long does it last?
Reading a lot of positive about McGuiars premium marine wax as a great base, and then using a hot sauce or other as a topper. Anyone with experience there?
Yeah two steps seems annoying for vinyl. 303 work as a one step?
I am a Boat Bling Hot Sauce fan. It's just so easy to use and is cheap. Does a really good job if you just use it before letting your boat get really dirty. Very good on water spots, and actually works well on the glass too.
I would soap and water clean the whole boat. Really get all the old wax, protectant, etc. off the hull. Might have to buff and polish to strip it all down. Afterwards, use a really good wax, ceramic, etc. protectant to give a fresh base to work with. This is what I paid to have done before the beginning of the season. Now, I enjoy the boat all weekend and Sunday evening I use Hot Sauce and it cleans up like it never hit the water. Put it back in the garage and dread the whole work week until I can go back to the lake.
I will second the weekly hot sauce idea. It's not a heavy duty cleaner so you have start from a decent condition and then it keeps it looking awesome. If you're already in bad shape then you'll need to use something else I think. I wipe my boat down on Sunday's with hot sauce it looks like I just picked it up at the dealership. Host sauce is also great on the glass, which someone else mentioned as well. In the spring I'll remove all the wax and reapply and then do the weekly maintenance with Hot sauce.
This will be a new boat so starting condition should be about as ideal as it gets. I may give the McGuiars product a shot as an initial base. Then use the hot sauce throughout the summer. Only issue is this will be on a lift so might be more work to do it every Sunday...maybe I’ll make the kiddos hop in the water and do it. :).
May go with 303 on the interior to start as well given it’s very good reputation for UV protection. Then when cleaning is needed, use soapy water and reapply unless I can find a good all in one.
I have always used 303 on the interior but recently Star Brite sent me a care package and I have been using their Fabric Guard which has a UV protectant in it. I can usually just use warm water and a microfiber cloth to clean up the seats if it needs a little extra I use Maguire's all purpose cleaner then wipe with water and follow with the Fabric Guard. Outside I use Aero space wash and wax and that has kept the boat good as new. We drive 5 or so miles on a dirt road so sometimes it seems kind of pointless but it still helps a ton.
My boat sits in the water 2 months straight. Used spray nine marine to de-gunge it and then hot sauce to remove the water spots. It worked quite well. Now I have to figure out how to remove fender rash from the gel coat! Any ideas? Acetone? Mequires diamond cut and a buffer?
Next year, I am going to pull the boat weekly and clean it - end of season clean was embarrassing.
Sent from my SM-G991W using Tapatalk
I use this stuff inside and out. Cleans and provides a light wax all in 1 and can handle water spots. Disclaimer I am not after a museum quality finish throughout the season but this gets pretty close with little effort.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Anyone put ceramic on their boat yet? I'm curious what you do for daily/weekly maintenance for things like water spots, which I assume is still a thing. I've read that you don't want to do something like hotsauce since it has a wax additive that will just screw with the ceramic coating. If someone has done it are you satisfied with it?
I have done ceramic on 2 boats now and very satisfied with it.
Not all ceramic is the same, and it will only look as good as the prep you do before applying it.
As far as weekly maintenance, I use a quick detailer/waterless wash with some white vinegar added, works great.
End of this season I tried hot sauce and was equally happy with results.
Yeah, it looks like the prep and application is super important. I was looking at the glidecoat products and I think they have a maintenance product but didn't know what others had done. It seems more rare in the marine space so I was curious what others thought of the results and maintenance. Thanks for the reply.
Not terribly popular on this forum. It’s rather expensive unless you have the ability to do it yourself.
I did a brand new SA last spring and even new the gelcoat needed quite a bit of polishing and correction. I used IGL marine which is pro only. I have a pro friend that coached me and was able to sell me 200ml for the boat. I had just under 30 hours into polishing/correcting and applying 2 coats of IGL Marine to all gelcoat and the trailer/wheels.
I do the waterline up, basically all gel coat exterior and interior minus the hull.
I did not apply to vinyl as chilltech vinyl is very specific not to use anything but Dawn soap on it.
Gloss readings from the factory were upper 80’s to low 90’s (out of 100), with correction I got it to 96-99 with a pro grade gloss meter.
