Has anyone done the conversion to the new software yet? If so, could you post some pictures of the updates to the Autowake screens?
Considering doing this for my ‘21 Makai.
I have the 2022 software update, but I don't have pics of the new and improved screens.
The Moomba website has pics with descriptions of the additional screens:
https://www.moomba.com/autowake/
Thanks for the link ... should have checked there first.
How are you liking the updates so far? Did you have to take it to the dealer, or just get the software from them?
I received the update from SC. It was easy to install.
The new additions are nice... where to seat your passengers along with knowing your current displacement.
I was having trouble with my goofy wave washing out and it seemed to have resolved the issue.
does this software work with any of the older models like a 2019 with the 7" screen?
@MondoKen did you have to take the boat into the dealer to have the software updated or did they send it to you? Did they charge for the upgraded software?
How do we get a copy directly from SC?
How are you getting access to the updates? It seems like you need to take it to a dealer to get it loaded, is that correct? When I had my on the water demo of my boat the tech made it sound like it was easy to update but referenced a tool you needed to format the usb stick and load the software.
It is super easy just make sure you have a good USB drive. Hardest part is finding the USB cord behind the helm. When I updated to the 2021 software it took me about an hour to find it under there. This time took me 3 mins to remember where I zip tied it back to.
I wasn't going to be the one to put it out there that you had it but now that you have Thanks for the help!
For those that have done this this year or in the past was your USB cord White as well? This might help others when trying to locate theirs.
Does the software update also include the go home logic on earlier models (2019)? I am most interested in leveling out the boat without asking people to move around. Effectively using the surf tab as trim tabs.
I got it completed yesterday and took the boat on the water. The new settings are pretty cool under Autowake.
It adjusted timer settings on ballast, default tab positions, and other settings. Will play more with it in the coming weeks here to go through all the new screens.
I'm having difficulty locating the female USB on a 2021 Mojo. I’ve removed the subwoofer and gotten right in there...no luck.
Does anybody have a good picture of its location.
This is without a doubt the hardest part of the entire thing. Don't have any pictures but the way I found it is by locating the wires that came from the screen which obviously the highest and furthest part to get to from there (Literally every other wire for the boat is closer to you and blocking you from
it) Then just kind off sorting through them. Note that it might not be a black cable as mine is white. I have asked people to post about the color of their cable to see if there is any kind of consistency to help people located it but no luck so far.
Will the USB plug in the dash of the Makai work for this? Talking about the one up next to the phone charger. I use it to play stored music all the time on a USB stick.
My 2019 Mojo was fairly easy to locate...I got underneath the helm and it was tied up to a bunch of wires...female USB end....white\grayish in color. Might be a bit harder on the Makai\Kaiyen though as different models
On the SA the service USB is in the dash box. On the Makai, I’d have no idea.
Making my new SA build come true!!!
Good to know where the Nav dongle is!
On the Vision control system, can the updates be delivered through the wifi connection? Is the PCM able to update this way?
Everyone should always know where their dongle is! [emoji1787]
Yes I would say the cable is 12ish inches so in the general area. It is not in wire loom or anything. It is just zip tied up and like Larry said if you have the maps there is a very small thumb drive plugged into it that is black. It barely sticks out the end of it.
Glad to hear your’s was the same color. That should help people
Here’s the location of the female USB under the helm of my Kaiyen.
I had to access it from the bow through the seat back in front of the helm.
https://uploads.tapatalk-cdn.com/202...894bc87978.jpg
Just a heads up, we recommend that all software updates be done by your dealer. There's more to it than just updating the software, and it's dependent on many other factors to work correctly. You run the risk of bricking your boat by not allowing a certified tech to handle it. Basically, we do not recommend doing this yourself.
Found it...white wire and white USB attachment. However the business end was wrapped up in a black rubber sheath and tucked up in a bunch of wires below the screen making it difficult to find.
I did not choose the Navionics mapping option.
https://uploads.tapatalk-cdn.com/202...7685e28614.jpg
