Originally Posted by
Holdmybeer
Huge help.
What I see here is the ECM is the ground for the fuel pump relay (Dark Green/White) - Check continuity to ground while turning key to "RUN" position. This would assure that ECM is triggering.
Check Pink wire from fuel pump relay fuse with ignition in "RUN" - should have +12V - if not check fuse or connection at fuse block
If the relay is clicking - should be able to feel this also - when switched to "RUN" then control circuit is good.
Another way to check is to test 87A (unused) on the fuel pump relay - it should have +12V at all times unless the ECM is telling the fuel pump to run. After 2sec, this should go back to having power, if the circuit is working correctly.
Not sure where "FROM SYSTEM RELAY" is providing power, but this could be the problem if no power anywhere in this circuit, and fuses are all good.
I know for certain, that the ECM will be in lockout mode and not start the engine for the other sensors I mentioned earlier, but the initial 2 sec run should function every time the key is switched and the gauges go through the reset process.
