1 Attachment(s)
help with shower install on Raptor engine
So i need a little help planning out a shower install on my 2021 Craze. I've done it on my older boats but with the closed loop cooling i'm trying to figure out what's the best way to do this. As far as getting the hot water hooked up i can't tap into the engine because it's a closed loop so is my best bet tapping into a water line coming after the heat exchanger? I would assume this is where the hottest water is? In this picture at the top of the heat exchanger there are 2 lines that come off and go to both side of the engine into the manifolds and then out the exhaust. This seems to be the best spot to attach the hot water line that goes to the shower. I'm i right on this? I'm guessing the water won't be as hot as getting it straight off the engine block like in my old boats, but is this my best option? Any thoughts would be appreciated, thanks.
Looks like these work on open or closed cooling systems.
https://heatercraft.com/products/flu...=4076466864159
Tap hot water from after your raw water heat exchanger and cold water closer to the intake side of raw water.
This would leave your in boat heater fully functioning.
