Indmar Contact - Overheating
Figure its probably a long shot, but does anyone have a good Indmar contact? Our 2020 Makai has been in the shop for a long time now and our dealer has sent in the problem to Indmar with little to no response out of them. And being its under warranty they cant really touch anything without Indmar's approval. So hoping I can get a hold of the right person to get something moving along faster. I even have Skiers Choice customer service trying his contacts as well.
The issue is that its overheating throwing a EMWT1 code. Note ran perfect March through August, when this all started. Under a heavy load or high RPM it will heat up to 190-200F, throw the code and CEL, then shut down sometimes as its programmed to do, if I dont let off first. But if you drop it to an idle or right above an idle ~1000 rpm within 20-30 sec it drops right back down to 165F. We know its not the impeller or fresh water pump or intake blockage. Closed coolant side far as level hasnt changed and appears to be good.
Ive tried searching other forums as well but havent found anyone with this same issue that wasnt just a bad impeller. To me it might be a heat exchanger issue or potentially a bad T-stat but they cant pull any of it off without approval first.
Any help would be greatly appreciated.
Water pump
Impeller
Thermostat
Water passage blocked
Cracked cylinder head
Blown Head gasket
Air pocket in heat exchanger
Low coolant
Air pocket in engine/cylinder water jackets
That’s all I can think of.
Most can be easily eliminated with inspection or replacement. Not sure why your dealer is so hesitant or clueless. This isn’t rocket science.
For the record, it sounds like SC eliminates bad dealers frequently.
Bottomline, new boat not working and under full warranty is 1000% unacceptable. No excuse that it’s not rectified in 2 weeks or less.
Might be time to contact an attorney.
