07 Mobious LS low temp and water in bilge
Picked my boat up on Thursday, took it out and have about an 1 1/2 hours on it . Two issues, one the engine doesn't appear to heat up past 135 degrees and lot's of water in the bilge. I can't see where the water could be coming in from? Drive shaft seal maybe? But I thought it was dripless? And I beleive the temp issue is the thermostat as the heater isn't that warm either. I know I should just run it back to the dealer, but at over a 120 mile round trip it's cheaper to fix myself then pay the gas to get it there.
Any one else encounter either of these issues on their new rig. Other than that, once broken in this is going to be great!!
Re: 07 Mobious LS low temp and water in bilge
Quote:
Originally Posted by h2oskierrick
one the engine doesn't appear to heat up past 135 degrees and I believe the temp issue is the thermostat as the heater isn't that warm either.
Cold is better than warm. But it is tough to break in a cold motor. My problem went the other way. My first thermostat ran hotter than normal.
Couple bolts, replaced.
