Bilge pump
Need help,bilge pump not working in manual,already checked fuses,fuse was blown at battery and pump worked earlier in day. light isn't turning on switch either. Put volt meter on switch and no power going to it,auto is working already filled with water and is working. Anybody know if brown and white wire has power when checking with meter,followed the wire and couldn't find any voltage,2016 craz any help would help
Did you check the breaker under the dash as well?
Yea stazi I checked it I even checked it with the blower fuse
You need to find out why the power going to the switch to turn it on manually isn’t there.
I put my meter everywhere I could find the wire and couldn't get any voltage
That’s the problem then. 12V to the switch needs to be there.
Orange wire to my switch has voltage and the ground is grounded but brown white wire nothing
When you flick the switch the brown/white wire should go 12V. The ground there is only for the light illumination.
O ok but yea I flip the switch and brown wire has nothing
Weird. Switch might be bad. Try jumping the orange to the brown and see if it kicks the pump on.
Will do
Bypassed it and it turned on,so I'm thinking it's this https://uploads.tapatalk-cdn.com/202...7285d87b97.jpg
Could be. At least you narrowed it down and figured it out.
I'm trying to find another one, not sure if I need it,I had one on my rv oven fan and I bypassed it...
Wtf is it? A fusible link? Shouldn’t need it if there is a breaker for the bilge.
I'm still looking to see what this one actually is but on my rv it was a thermal cut out switch so it doesn't overheat
