Engine shutoff during ballast fill
I have a Moomba mobius LSV (2005). And it has the original gravity 3 system, whenever I fill the ballast, occasionally the whole boat will shut off including all electrical, after about 3-5 mins it will have power come back on and you can start the motor. I know it’s not a lot of detail, but any ideas on what causes that? I looked at my ballast system and drew a rough diagram although I didn’t trace all the wiring. I want to replace the whole thing and intend to, but wasn’t sure if there was an easy fix to prevent this from happening.
https://uploads.tapatalk-cdn.com/201...a1c8940df8.jpg
Quote:
Originally Posted by
Turbinesurgeon
That’s interesting. My 06 with gravity games has three switches and a circuit breaker on the panel. I assumed they were all like that. That’s what I get for assuming.
Yeah I think they skimped out on adding the last valve, it does have 3 tanks, but it kinda fills them all weirdly, combines two of them into one zone. Honestly if it had manual valves it would be so much easier because the electric ones don’t close all the way and so you basically get one bag filling slowly and the other bursting at the seams, kinda stupid.
I’m going to get the reversible pumps and my ultimate goals is to have 4 switches: front, middle, and left/right rear.
There’s NO WAY your battery is 24V. Not a chance. The electronics on Moombas are made to run on 12V, period.
How on earth did you come up with that idea?
Post pics....I need to see this!
