I have 97 Outback. I need to rebuild the Carb and believe it's a Holley 4010 carb.
How do confirm this and where to locate a rebuild kit?
Check with these guys.
https://www.skidim.com/
If it is OEM, the number on the carb is a Moomba number and needs to be cross referenced to the Holley number. The power valve in the kit is not the same as in the kit so that needs to be ordered separately.
My buddy owns a "hot rod" shop near me and he sells the rebuild kits and all the individual parts.These shops are getting hard to find!
Thanks, I called Holley and had to get the number off the carb for them to get me any info. Now on hold for 30 min or more. Thanks for the help, Love these knowledgeable guys
Ok Holley say they can't tell me what power valves are in the carb only that the kit comes with a 6.5 power vale in it. I don't know the idle vacuum.
Any ideas? Will the 6.5 be the correct one?
Any input?
Wow... just didnt want the down time waiting on other power valved
you might try over on the supra forums. lots of older boats over there that guys are restoring. they might know based on the engine.
there's not much posting over here with the older moombas even tho there's a ton of them running around so odds of finding that 1 person that did this work and actually remembers the part will be slim.
It's probably a 4010 Holley carb. Check out this thread I made last year...(I even have the carb rebuild kit part #)
https://forum.moomba.com/showthread....96-1998-Mobius
Buy this book...
https://www.amazon.com/Holley-4010-4.../dp/1555610196
Take a bunch of pictures and take your time. Pull the power valve out and see what # it is. If your Goolge-Fu is strong you should find references to what valve you want. If you go to a speed shop they should be able to tell you what valve comes in the kit. If you're unsure what comes in the kit, order what you see on Google. The valves are cheap. Record how many turns out the mixture screws are. Write it down.
There will be a LIST# stamped on the choke plates. You use that as a reference for the kit. Look in my post and I have some pictures.
My 2003 outback blew a power valve last year.(was pouring gas down the carb throat,wouldn.t idle) My buddy at the hot rod shop had a box pf misc. parts. The power valve he gave me was a 2.5 i believe.Installed it and the boat runs great.These boats do not pull much vacumn when under load.
On edit the power valve was a 4.5.
