Anyone know which cylinders 3 and 5 are looking at the motor from the front of the engine thanks.
Ford broke the cylinder labeling rule. Lol
They label theirs 1-4 on one side 5-8 on the other.
So if you’re looking at the engine from the swim deck (cus that’s closest to the front of the motor) 1-4 is on the right side.
Ford:
8 4
7 3
6 2
5 1
GM and everyone else in the known universe:
8 7
6 5
4 3
2 1
16 spark plugs and 2 coils 1000 from the dealer! Lol
Just pull the plugs and cross reference to the NGK, that's what I did on our Mojo, was still around $120 for 16. Never missed a beat. The coils can be sourced from one of your local auto parts store as well.
Motorcraft SP-526 Spark Plug https://www.amazon.com/dp/B004A2EQEA..._1Xz7CbGS6WWQ9
$4 each on Amazon
Are the stock plugs iridium or platinum?
https://uploads.tapatalk-cdn.com/201...01ae94143e.jpg platinum
The coils are ford as well but they spray painted the part numbers so hard to read
Motorcraft SP526 and CYFS12FP are same plug.
Again, $4.05 each on Amazon
Here are all the rock auto equivalent plugs.
Factory are double platinums.
https://uploads.tapatalk-cdn.com/201...f4f9bd7d29.jpg
Factory coils are Denso’s and $58 each on Rockauto
Are you sure about this? I am relatively new to boats, but was an automaobile mechanic for several years. Ford cars always numbered 1 - 4 on the PASSENGER side of the car. If you were standing on the swim platform, looking at the front of the engine, it would be
4 8
3 7
2 6
1 5
I do better with pictures
https://uploads.tapatalk-cdn.com/201...fb6501fe0e.jpg
I see a pic of home plate
Lol, straight off Indmar’s site.......
https://uploads.tapatalk-cdn.com/201...36d4c6cf72.jpg
Got the plugs replaced today looks like someone did a half azz replacement before already, https://uploads.tapatalk-cdn.com/201...c4363fa84a.jpghad two different plugs in it
What plugs were in cylinders 3 and 5?
The blue ones are newer and we’re on the exhaust side. The intake plugs are the original ones. Each one had one of each. I swapped coil and plug wire from 3 to 1 if it misfires again it’ll be easier to just change the coil packs.
Anyone know how to clear the check engine light. Sure be nice if there was a obd 2 port some where hidden
On a car having the negative terminal disconnected for several hours (18 - 24) will usually clear the code. You can also disconnect BOTH terminals form the battery and then touch the terminals on the WIRES to each other. Be careful and don't create a direct short. Use a volt meter to be sure the wires dont have any voltage.
