November 2018 Picture Thread
Well, I made it to November again! Today was another test run after throwing even more parts at my engine.
The HP and LP pumps I installed didn't fix my problems.
This round I replaced:
- New alternator (I had previously bought)
- New plug wires
- New Coil Wire (I did find corrosion on one of the ends of the old coil wire)
- Re-gapped spark plugs to 0.060" spec
- New ignition coil
- Fixed a part of the ignition coil control harness where it had worn through the insulation expose a tiny bit of the conductor
I ran it through the paces. There and back 7 miles each way at 3500 RPMs. Then four of the 2.5 mile lengths of our slough. 1 with no ballast at 28mph, 1 with 1180lbs at 21.5mph, and 2 at 10mph with 3000+ lbs of ballast. No issues and the fuel consumption seemed better than it's been lately. So hopefully I'm finally in good shape.
Water was so smooth today!
https://i.imgur.com/6RyHuU7.jpg
She's ready. Comp vest under the drysuit just in case.
https://i.imgur.com/pl7v7Iy.jpg
Wife took a surf set. Water temp is in the mid-50s. Sure we could do wetsuits, but drysuits are way more comfy!
https://i.imgur.com/aZESaEu.jpg
If you see a pirate flag at half mast, what does that mean? The wife thinks it represents Zombie Pirates.
https://i.imgur.com/U1yitOI.jpg
2 Attachment(s)
Yay first time out for the start of the season here....
Just a couple of pics from our first venture out, weather has been pretty poor till now.
Attachment 27829Attachment 27830
Pics of Lake Eildon around a place called Jerusalem Creek.
Was also Remembrance Day so 1 min of silence taken at 11:00am, was quiet for sure.
Tried out a Ronix Potbelly Cruiser surf board, wow heaps of fun, thigh muscles still recovering from the excitement!
Cheers BruceR, Melb AUS.
You can save a lot of money just by removing all the staples attaching the skins to the seats. This is time consuming for an upholstery shop. They have to be gone to attach the new skins and new staples. Make sure they use stainless staples. My friend owns and upholstery shop here in Florida and luckily we worked out a deal. All it cost me was material but I removed from boat and removed all staples. On your curved cushions you need to make a template so the upholstery shop knows how the cushions goes back in or you will have wrinkles on the curves. I see a lot of pictures on here after people have them redone. It looks terrible. If you have any questions just let me know.
