If you go the gate route and want to stay on a budget for the controller, I might be able to help you out. Wake logic is a great controller, but not everybody can afford $1100. I have a controller that uses three one touch buttons to fully deploy, retract and switch sides. There is no gps speed window like the WL, but it is very easy and intuitive to use. Push GOOFY button to to deploy the starboard actuator fully and light up the LED switch then ride goofy. When the rider goes down, push WIPEOUT and any gate deployed retracts so you can drive back easily to pick up the rider without any steering issues. When the rider is ready just press GOOFY again and away you go. Riding regulate works the same way. If while surfing you want to switch sides just press the opposite button and the deployed gate will retract at the same time that the opposite gate is deployed along with the corresponding button lighting up. Like I said it is very simple and easy to use. It comes with the controller and the buttons pre wired. Just hook up power/ground, two wires to each actuator, drill for the buttons and plug them in. $450 plus shipping. PM me if you are interested.
Attachment 26646Attachment 26647
Sorry for the old video. I need to make a new one.
https://youtu.be/rXv1TSn3Ogo
