Originally Posted by
Broke Pilot
It's probly just trivial stuff to the normal person, but to me as a mechanic and off-road 'enthusiast', it was just an annoying truck.
The grease/moly paint they use on the frame for rust proofing is first and foremost the dumbest thing I've ever seen. It's infuriating to do any work under the truck. You come out covered in that crap and it sticks to everything for months. Can't wash it off for obvious reasons. Me n my brother were covered in the stuff after we finished the lift.
The front suspension was another odd item. It's pretty poorly designed with the solid mounted top coilovers. Nothing pivots in the same direction on that front end, which makes it ride funny. (Maybe just me...)
The electrical side of things in the truck was hard to deal with if you want to put a nice stereo in. The 8" mylink was nice, but it controlled the entire truck. So it couldn't be replaced easily. All the door chimes and seat belt chimes run through the stereo and out the speakers. If you want to amplify the highs, you get door chimes at 60 watts. Plus, there was no full range signal to some of the speakers. So you had to sum them together, which also summed, you guessed it, the door chimes!
But on top of all that, the recalls were killing me, and then the dealerships not doing the work correctly really annoyed me. A simple computer flash turned into replacing the steering column when I left the lot and lost power steering.
So, that's why I went back to Dodge/Ram. Most stuff is still mechanical and easy to work on with out an engineering degree. Plus, I missed having an oil burner. Lol
