Originally Posted by
goose
On the upper arms, it does use the same hole pattern. The arm itself is just bigger. On the 2014 LSV, unfortunately that kit number doesn't exist. The LSV has it's own hinge assembly that is unique to the other boats. We do have a kit for AutoFlow on 2014 and 2015 LSV. However, like I said, we didn't do the LSV for 2016 so there is no AutoFlow 2 kit for the LSV. Again, it is theoretically possible, but it will require parts from an AutoFlow kit and an AutoFlow 2.0 kit. The dash can be reprogrammed, but obviously getting the parts you need without the parts you don't need might be quite difficult and could be costly. Again, you will just have to contact your local dealer and work through that one. They might be able to get ahold of our vendor that is doing that for us and work out something, but I can't promise you anything. We do our absolute best to try and make sure things are as retrofittable as they can be, but obviously there is always a limit because we have to put the majority of our efforts on our current production needs. I am sure you can understand. Good luck on your project.
