Wiring Wakemakers Gravity III Upgrade to Factory Switches
I know some of you have done the upgrade from Wakemakers, and it says right on their site that it doesn't include instructions for how to wire to the factory switches. I know that the upgrade kit comes with pre-wired connectors, but I have some questions around that.
1) What is the best way to route the electrical from the pumps to the switches? (I plan to put all three pumps right under the ski pole.)
2) How do I get power from the battery? Is there a fuse block under the helm I can tap into? (Boat is in storage, so I can't look.)
3) It doesn't look like the kit comes with fuses. Do I need to put in-line fuses in? From what I've read, I will need 25's.
Pictures would be very helpful if anyone has them or can take them. I appreciate any advice anyone has!
Re: Wiring Wakemakers Gravity III Upgrade to Factory Switches
How many batteries do you have and where are they?
2 batteries and a Perko switch. Located under the passenger (port) seat where most are.
2 Attachment(s)
The previous owner installed the perko and 100amp breaker and a buss bar instead of a fuse block, the 25 amp breakers are longer than normal fuses. I used fuse adapters instead of replacing..
Any pictures of your thru hull locations from the inside?
Sent from my iPhone
Don't have any on my phone, but will take some next time I'm at the boat.
