I am interested in buying a 13.7 X 17.5 4 blade prop the OJ # is 456. It will need to fit a 1994 MasterCraft Maristar 225VRS, LT1
I do have an OJ Fusion Edge prop that I can't use on my boat (too large of a diameter).
I'll report back with the size later this evening.
e
prop I have is the OJ XMP Fusion Edge #532 (I think it is 532)
14.25 x 14.5
1 /8" shaft
The 456 fits a splined shaft which is unique to MC. I have a 13.7 x 17.5 in perfect condition but won't work for your boat.
I am trying to edit my post but have not found where to do it.
The OJ # 456 for the prop to fit my boat is not correct.
My boat is 1 1/8" shaft keyed not splined.
I think your prop probably will fit my boat. I was incorrect about the OJ 456 fitting. My prop would need to be 1 1/8" shaft keyed.
I'm pretty sure this is the one I have in a box on my shelf:
http://www.wakemakers.com/oj-456-propeller.html
Edit: Yup. Just checked. That's the one. Great prop but I went to the ACME 1161.
if Kane doesn't have one for ya, I believe my spare is what you need. it was dinged lightly a few years ago, had it professionally repaired/balanced and has not seen the water since.
pm if he doesn't hook ya up.
would give me the opportunity to buy a more appropriate spare for my boat. the 13x17 is wrong size.
13.7 x 17.5 for 1-1/8" taper keyed shaft would be an OJ 454. Looks like several people here have a spare they would be willing to part with. That was the standard prop on Moombas in the past and most people upgraded to handle extra ballast. PM me with an offer. Mine is in the box collecting dust.
the one I have - I believe has never been used and if it was it was it was on a LXV for only about 20 minutes.
Not enough clearance between prop and trailer to use on my boat.
I'm really not sure what model number it is, but was told by an OJ Rep that it was an XMP Fusion Edge.
The shaft size should read 1 - 1/8".
If anybody wants it, send me a PM. Willing to trade prop for new backpacking tent.
Hey VA LSV I have sent you 2 PM's but haven't heard back from you.
Like this? This is like new reconditioned from OJ props. I'm not using it so make me an offer.
Thanks,
-RickAttachment 20975
