Transducer Mounting In-Hull
Can someone tell me what type of glue you use to mount the in-hull transducers. I have gotten two very passionate answers about this from the two people I asked. One answer was to use the normal 5200 through-hull glue that you use for ballast fitting and below water line stuff and the other answer was absolutely not to use that. I was told to make a ring out of RV silicone and fill it with a 2 part clear epoxy. I was told that the 5200 would block the transducer.
Can someone please let me know I am about to mount this thing and need a clear answer. Thanks in advance
I used epoxy. Works just fine for me...
Quote:
Originally Posted by
chadjitsu1
So you used the 2 part epoxy (5 minute) stuff VS using the 5200?
2 part epoxy. I do not recall the type (set time).
I used clear silicon caulk and it has worked great so far. I went this route to allow myself to move it if necessary with out a lot removal work.
Ian Brantford
Do you have a picture? Thanks.
I'll pull the cover and get a pic for you.
Short answer, yes you need to be in water
