Upgrading the ballast? But from who?
Looking to switch the sacs out in the back of a Mondo and was wondering if there is a set of bags that will fit in the back lockers that are made specifically for the Mondo yet or will any old 750 bag do. And does anyone know what size the bag in the center is on the Mondo?. I know the 1300 pound ballast is standard but I don't know how the weight is broke up between the 3 bags. Thanks in advance:grin:
Check your PM.
What are the dimensions of the v-drive lockers? Would go 1100 if the dimensions are close. You can always underfill a 1100 but can't fill past 750 in a 750.
Would even suggest the 900 sumo sac if the dimensions are closer.
Quote:
Originally Posted by
dusty2221
Can I get the code pm'd also. Thanks
Sent from my SAMSUNG-SGH-I747 using Tapatalk
What for?
You must first confirm that you will be in a Skiers Choice product in 2014. I read a nasty rumor on here about you a few wks ago.
Drew, I thought the same thing!
I have a mondo Newley 3 weeks old. Can not surf it stock ballast. I've talked to wakemakers and the Enzo bags will also fit for the back lockers. Ordered two for there and also a integrated skiers choice package for the bow under seats hooked into current hard tank and vented. Should be killer once installed and running.
Dusty? You had a buyer in the north for your boat. Don't tell KG but the red and black is a deal maker. You better not have sold.
