2005 Mobius LSV not getting fuel to the engine
I have a 2005 Mobius LSV that won't start. I've never had this problem before, it's always started right up, but when I went to put it in for the first time this weekend, it wouldn't start. The engine turns over fine, but won't start. At first I thought it might be the kill switch but checked it by bridging the two wires and that did nothing. Then we pour a little gas in the throttle body and it started right up, but stalls after the gas runs out. We checked the fuel filter and there's fuel in it and it's not clogged. Has anyone had this problem, and is there something else I can check that would cause this?
When is the last time you changed the fuel filter?
Sounds like its not getting fuel, so run through that system. Filter, pump, etc.
Is that a carb or fuel injected motor?
Quote:
Originally Posted by
Garland21
It's fuel injected. I've never changed the fuel filter and I bought the boat new in 2005. We pulled the fuel filter off and blew on it and fuel came out of it, so I don't think that's the problem.
Start there. Cheap & easy and really something you need to do every year, especially with the ethanol gas.
Re: 2005 Mobius LSV not getting fuel to the engine
I had a problem with the wire going to the bottom fuel pump. I bumped it when working on the ballast it would cut in because of bad contact. That would be enough to blow fuses.
Sent from my SCH-R970 using Tapatalk 2
Have you tried skidim?
http://www.skidim.com/
