Got Prop issues? I just got the Diesel of Props. ACME 1617 its a beast
I was runing the well known OJ Wake Board prop 14.25 x 14. This is a really sweet prop, awesome hole shot and great acceleration but has 1 huge limiting factor, noisy, lots of vibrations.
Up untill last summer i wasnt having to much problems and once i hit that magical 3K ballast mark my prop started to show its weakness. If i was running a surf wake apx 2200 lbs plus people i couldnt get over 15mph, why would you want to? If you need to hit the marina or drop someone off at the doc but you had your wave all dialed in, you dont want to drain and refill. Just put everyone on the opposite side and roll out. Well i couldnt as the prop was maxed, she was giving all she had.
I talked to Spencer at wake makers and asked what he thought was the best prop. This year im running nearly 4K ballast plus people and i dont want to hear prop growl, vibrations, or have hole shot issues.
Joking he said ill hook you up with the Diesel of props. This thing pulls like your truck does. Its got a little lower top end of course but the power in unreal in a prop, and its actually smaller in diamiter for better trailer clearence. I personally dont have that issue as i had my bunks all raised the first year.
I got this prop and installed it.
The ACME 1617 4 Blade propeller offers the most aggressive holeshot and acceleration for heavily weighted boats, but in a slightly smaller diameter for boats that have clearance issues.
If you use your boat entirely for wakesurfing and wakeboarding, and have added a significant amount of additional ballast, the ACME 1617 propeller will restore your boats acceleration, speed holding and fuel economy.
Specifications
Diameter: 14"
Pitch: 13.75"
Cup: .105
Rotation: Left Hand
Shaft: 1 1/8"
Water test time. Leaving the doc, its super quite, hit it up to 11mph to see what surf speed noise, nothing silent just engine noise. I was feeling pretty good about this prop.
I slowed down to idle then punched it. Boat jumped out of the water on plane in about 5 seconds and was doing 28 before i even looked at the speedo. Wow not bad but the boat is empty.
We loaded up the nose and some rear weight for wake boarding and off we went. I took it easy on the pull ups as i knew this prop was stought. I got out there and pull ups were great, but still nothing really different then the OJ prop just ran a lot quiter.
Yesterday was the real turning point of this prop.
We had the surf wave dialed in and were surfing. Claudia gets off work comes tot he lake, text me shes at the doc. Were across the lake, so i get back in the boat, we all sit on the opposite side, were running axp 2500lbs of ballast for surfing. Wake plate down and we hit it, 10 comes fast, then 15, then 25 and then 30MPH smooth no problem for this prop at all. Me and Steve were shocked as the OJ wont go over 15. We slowed down to 25 as thats teh cruising speed i prefer. Ran over to the doc and picked her up. Enjoyed the rest of the day. This prop is simply amazing. You dont even realize the power of it till you weight the boat, its as if when you weight it the prop knows it and really comes to life.
Then came the last final test, 2 days on the lake both days were 4hours on the engine. This is very average for us and im pretty consistent 1/2 tank a fuel a day in the boat, as we will up every time we go out. 20 gallons a day average over 3 summers, when we goto the Hagg.
Both days it only took 14 gallons to fill up. Thats a 6 gallon savings over normal and at 20 bucks a day savings that means every 3rd time out is free LOL compared to our normal cost. Now i know this is only the first week, ill be keeping tabs. A savings of apx 1 gallons per hour of running is very respectable.
http://i639.photobucket.com/albums/u...DSC_0109-1.jpg
Quote:
Originally Posted by
BrokeGuy
Mike, what boat do you have. I'm wondering if this prop will give me the same results in my craz.
2016 Moomba Craz
Gunmetal W/ flake
Atomic Orange Accent
Black Deck and Hull
This thread really peaked my interest too. From what I can tell he was running an lsv when this thread was started in 2012. I'd be interested to know what he's running on that mojo 2.5
I didn't check the date on this thread, wondering what was up. He sold the prop in this forum. I'm assuming because he sold the boat.
I ran the 1617 in my LSV, and it was a beast. It ran 1 1,110 bag fine along with the center, ibs, and an extra 400 lbs, but I think running 2 1,100s at the same time would've been too much. The engine just didn't have enough power to do all of that.
I pulled the 1617 off the LSV when I traded it, and will use it as a weekend saver prop only. I called Wakemakers and they approved of it for that. For the mojo & craz, I believe the Acme 1235 or 2079 would be the ideal replacements
https://www.wakemakers.com/moomba-wa...oat-propellers
mmandley
That doesn't sound right at all, did you have any nose weight? When I had the 1617 I was running 3K to surf and was able to get to surf speed no problems.
When wake boarding we would run 2500 even and it would get up and go just fine.
400lbs of human ballast in the nose. I wasn't even pulling a surfer. What elevation are you at? The 1847 I'm running had no problem with all ballast full + 5 adults.
Jeepers
I just tried tried the 1617 with horrible results. I've been running the 1847 and quite happy with it. Based on the reviews I've read here I thought I needed to try this thing. Ran great with zero weight. However, once the ballasts were filled 1900#'s I could barely get the boat to 10mph. Full throttle, 3400 rpms and maybe 12 mph. Couldn't even get the boat to plane. Needless to say it getting shipped back asap.
I see you live in Spokane too. I run 1617 prop on my 13 LSV and never had those issues. Unfortunately I bent it at Long lake last weekend and now have to run my 537 tell it's fixed.
icemanftr
Isn't that funny. I should run it by precision propeller and make sure WM's didn't accidentally send me an out of spec. Prop. Now hat I have the 1847 back on I should re-test and make sure I wasn't experiencing engine issues. I guess this is one of those times when the enemy of good is....
mmandley
I was in OR at the time, I think it was 1500-2K elevation.
I would have to lean on that 400lbs of nose weight vs the huge amount of tail weight was why you didn't plain.
I am not saying your wrong by any means, I just know how I ran mine when I had it lol.
The important thing is your happy with your performance, I just never had an issue with the 1617
But the 1847 would plain perfectly with the same set up plus more human weight in the back. The other issue, was full throttle and couldn't plain. The 1847 popped right out ran between 2800 and 3000rpms and I had a ton of throttle left. With the 1617 the throttle was buried; couldn't plain or push her passed maybe 12mph. It sounds like I may have received an out of spec prop from WM's
When I had my LSV, I would run 1,500 lbs stbd, center full (whatever that was), and 600 lbs in the bow. The 1617 was the beast
Out on the water messing around right now. I've got an 08 LSV with the stock OJ prop (13.5x17.5 I think). Empty I ran 39 mph at 4700 rpm WOT. Wake ballast (1600 lbs) I ran 38 mph 4500 WOT. Since that is all within the range 4400-4800 per owners manual, I should be good. If I choose to upgrade to the 1617 for more hole shot, my weighted WOT rpms should go up. Is it possible for them to be too high?
Talked to a propeller tech and he said the 1235 was the choice for many years and acme came out with 1617 to allow more room between boat and trailer loading. The 1235 on Moombas (certain models) will cause prop burn on gel coat and also peel away at gel coat, just like ski supreme and centurion are notorious for. Makes me glad I also went with 1617 to stray away from this issue. He mentioned the 1617 is a better prop for heavily weighted boats and runs less risk of damaging gel coat or catching trailer during loading.
