FYI: Just got an email from Exile, anyone that wants to pre-order one of Exile's new ZLD's jump on it! MSRP is $200 but for pre-orders it's an amazing $60 off! $140 is a super killer deal! Go HERE to check it out!
Attachment 13489
Attachment 13489
I have one going in my boat this spring, i got a change to fiddle with the live model back in the fall of 2011, almost put it in the boat then but summer was almost over and didnt want to rewire my set up. Since then several revisions were made and this item is sweet.
Its aimed towards the WS420 but its still very different.
Big thing is no Mic on this little baby.
Good thing, the eq adjustments are automatic in the fact you dont set the indivual frequency as you adjust it up and down on trebel and bass it move all the bands to there proper curves.
I know for some they like all the levers and switches but i can say since i went to Exile brands and use only there cross overs for tunning, i have never touched a bass/trebel adjustment again and the music sounds so much richer and cleaner.
I will be installing one in March time frame and will give some reports after the stereo upgrade.
I know this doesnt help you now if you want the discount.
dangnabit, this comes out now after I basically just got done redoing most of the system
where would you mount this
I mentioned several time Exile is comming out with new gear bro, This is why i mentioned im gutting my stereo, but cant say whats going in it, and also why it hasnt started yet. Still waiting on Exile gear to show up.
Boat does go into Wakemakers for new Ballast system going to be filling my new 4K ballast in about 10 minutes.
As for the LZD i bought a blank panel for the toggle switches on the dash a couple years ago. Im going to move all those switches up about an inch and flush mount this right under those.
Or it can be mounted under dash, or on the side of the side panel with the throttle.
PM me and i might be able to enlighten you on some things going into Fierah this year.
I really want one of these..
problem is I also really want a new board this year and gps-based perfect pass...
decisions.. decisions... decisions....
You sound nothing like your avatar suggests.
LOL, I almost called you lovey.
Gentlemen, let's keep the gloves up. I for one would love to hear how this is similar AND different from other options on the market like the ws420 and clarion eq.
Oh come on mods!!! Lol .. glad I saw that one :)
Well a couple differences from a novice point of view ...
The exile does not have a mic
The wetsounds is more technical where the exile is more simple minded.
The exile uses a fader style volume control between boat and tower where the wetsounds is independent zone volume control.
I keep seeing that exile has independent sub control. Not completely sure how that is different from adjusting the bass on the wetsounds.
What I am a little confused about is how I keep seeing exile peeps say there is no mic like it is a selling feature?
Fwiw, I have the krpyt version.
Sidenote: I am anxious to hear someone review the air puck and the differences between it and other Bluetooth devices. I did find it a little odd that noone had much interest when I posted over winter about using Bluetooth and when exile came out with their version more seemed intrigued ... Guess that is just my rant on a seemingly biased site
Sent from my DROID RAZR using Tapatalk
You mean after she installs your system?
IDK if the Exile not having a mic is a good or bad tng, I don't know if having a mic on the WS420 is a good point or bad point. Personally I have no use for a mic.
As for the differences in the zone controls,
WS420 allows the adjustment of the tower
It allows separate adjustment of cabin/sub
Exile allows adjustment of the tower
It has separate adjustment for the cabin
It has separate adjustment for the subwoofer
There is a separate adjustment for the sub comes into play for people like me is, I tune my sub and then I play some older music. It needs a little more bass so I can turn that volume up a little more to add a little more thump.
Say later were playing dance music with a ton of bass and now at full volume my sub is starting to over extend, now I can turn just the sub down a little.
When I tune my sub its based on sounds and also maximum safe volum based on heavy bass laden music. I dont want to worry about blowing my 2k sub setup. But there's times when at. Lower volume in the cabin you just don't need all that sub or you play music with less bass and want to crank just the sub up, the separate sub control allows this.
I can't give you the details how the processor works as in sound processor but it's a Burr Brown and if you know Burr Brown from the audio industry then you should know that type of level and quality and sound.
Even if I wasnt a fan of Exile then I still would lean to the Exile ZLD due to what it's got inside it, the fact I don't need a mic, and the fact so fare I haven't found any other marine, car audio that compares to the level as Exile.
As I stated before it makes little sense to mention a Wetsounds product in an Exile thread. But it has happened. So in order to correct perceptions about what the Wetsounds WS420 'actually' does without reference to any other product...
Wetsounds WS420 equalizer:
Two completely independent equalizers in a single chassis. One for the tower and one for the in-boat zone. Obviously the in-boat speakers are comprised of a 3-way system, are surrounded by a coaming structure and normally listened to within a 5 foot proximity. Contrastly the tower speakers are suspended in open air and are often asked to project at 80 feet. Wetsounds believes that IF you are going to use equalization that these two zones have little in common.
A paragraphic bass EQ. This dual control enables you to choose the hinge and turnover frequency of the bass gain control. So it addresses different subwoofers in different enclosures, different listening conditions plus different types of music including rock, country, hip hop or an old analog versus a newer digital recording. For example, if you want to increase the low bass then you can slide the bass region most affected a little lower in order to cut some of the boominess or keep the sub out of the vocal range. Or if you want more bass but you want to limit the potential for subwoofer damage then you can slide the frequency a little higher and impact a broader range of program material. If you want a little more bass while underway and in combination with your tower speakers then just give the bass gain control a little boost. A very useful tool if you just take a little time to fully understand its many applications.
The WS420 has a mic and a full PA system onboard. Its a great instructional tool for training the young ones, like, " Lean back and stop trying to PULL yourself up and out of the water. Let the boat do the work."
The WS420 has an auxilary input so that you can use any Bluetooth device with it.
Earmark Marine
That is not my understanding of the product. My understanding is that it uses a fader between tower and cabin, NOT independent volume controls. Although for the most part it accomplishes the same thing it is different. Example, 2 boats are tied up listening to the cabins quietly while the talk among themselves. Dusty's mom comes by and says I'll go home with the first one to play me some loud music. :grin: The boat with the ZLD has 2 steps, they have to turn the master volume up and then fade to in the middle or towards the tower. The boat with the WS simply turns the tower volume up. There is no master volume with the WS, it has independent volume control.
I don't believe the bass control works the same way with both. David looses me a little bit in technicality but I think the WS adjust the frequency? Either way, I have been able to adjust the amount of thump I get from my EQ.
Mmandley, in an attempt to tone down the bias, bc it does appear that you know alot about stereo (def not doubting you there) what else have you used that you are comparing to? From my understanding you went from factory kicker to Polk DB's to Exile? When you say you haven't found any other audio that compares have you compared to anything in the same class such as wetsounds, bullet, jl, higher end polk, etc? I'm not doubting the quality of Exile but to tout it as all superior makes me say "meh".
Disclosure: I do not have the WS eq. I have the Krypt version which from my understanding is similar to the first generation of the WS eq.
Which also happens to be extremely annoying when your on the lake relaxing and some azz hat blasting azz crap music keeps coming past you blaring at his kids over a mic. One of my local lakes is run by the Corp of Engineers and they've pretty much outlawed that. Some douche was out at 6AM near the campground doing the above and they ran him down and told him not to use it again as it's disruptive, invasive and reserved for law enforcement. Yup they said that. Thank gawd!
Can I make a suggestion here? Let's chill on the direction this thread is going. I started this to let peeps know about the deal, not to start a war or bash anyone.
A manufacturer can only provide an option, not control how the user uses the option.
It blows my mind how having an option is turned into bad thing ... and slightly annoying that the only ones that see it as a bad thing are the Exile loaded boats :rolleyes:
Exile, you have good products!! Tell us about your good products!! No need to tear others down, right??
Come on guys play nice.
Ws 420 and Krypt very similar , different components, does essentially the same thing.
Exile on the surface looks like a clarion eq with, better components , line drive and seperate sub control.
Fit the bill with your needs, razz was just pointing out a good deal.
Don't shoot the messenger.
Disclosure. I have owned all three brands, with no clarion marine and they all did what I designed them for.....02 cents
I'll respectively disagree on the mic with the preference that it should be used correctly and not by an "asshat."
I can envision where it would be extremely helpful for instruction while allowing the driver to remain facing/looking forward while watching the rider in the mirror. I've witnessed a few near misses with boats, docks, people, etc when the driver is turned around coaching and has lost sight of where they are going.
Maybe more useful to me is the ability to call off the asshats on the jeetski or 70's-era bass boat that feels it necessary to get right up on my rider to jump the wake or just get a closer looky-loo. Wish the po-po were as diligent with that as the noise coming from the tower.
Okay, so Razz shared a buy on a new product introduction to the members as a good service. Cool.
Then another brand of competing product was introduced into the discussion. I think that correction has been pointed out and we know what that has led to on this and other forums.
If anyone wants to get more information on the other product then start a new thread. I'll be happy to talk objectively about any product in nano detail if you like. If I glaze over something that is too technical then ask me to go into a better explanation.
Earmark Marine
In my boat yes thats correct on the brands. I also spent time listening to WS and there set ups. I just didnt care for the way they sounded. I listened to the Pro 80s, Pro 60s, and Pro 485.
As for car speakers i have had tons, Infinity, Polk, JL audio, Pioneer, Bose, Kicker, Rockford Phosgate, MB Quart, and several less the mentionable brads.
I was refering to Marine quality speakers.
Its strange because like said before this is a forum of public thoughts and opinions yet it seems when one person who prefers 1 brand makes any comment or comparison to another and someone else doesnt like it then it becomes this huge debate. This is the reason so many people call Wake World Hate World.
Like i have said before, Name a place and thread where i have ever Downtalked someones idea, thoughts, opinions of stereo brands. Never, you wont find one. I have never said X brand is worthless, or not worth buying, or anything.
Everyone has Brand loyalty thats the way it is.
If i make a comment about a peace of equipment and you dont agree then thats fine disagree, thats what called freedom of speech.
So often it seems especially in the electronics threads people get talked over the top of, and i for one can say this is why so rarly do i participate in the audio threads anymore.
So as for this thread ill step out. Moderators feel free to delete the rest of my posts in this thread, i frankly dont care anylonger.
You funny guy you.... Wait til I break out my 80, mesh half shirt, with my six pack I know I have somewhere. Lol
Fwiw. I agree with Wolfe on the mic, but it's only as good as the user... It's nice to have when you need it.
I am sure at the ww bump party's its a great wooing mechanism to get hot chicks on your boat... Lol
I can envision it as well, but unfortunately my personal experiences are just the opposite. It's a tool that has a potential purpose and should be used responsibly yet everytime i've seen it in use it's been just the opposite and very annoying. Everyone elses experiences may be different, these are just mine.
I agree with you 100% on this Mike, and that's also the reason I stay out of most of these as well. It seems that one cannot talk audio anymore without a bitchfest starting up with a war waged about the attributes of one brand against the other, and it's usually one against the world :rolleyes:
Guys - I just took 15 mins reading all these posts. I for one, like the moomba forum because it is a good group of people. I’m sorry to say this thread is beginning to look like a typical Exile versus wetsounds. David, why are you even in this thread? Let these guys talk. Everyone has their take on things. It’s interesting to see how Mike see’s the ZLD. And right or wrong, its not anyones place to discourage peoples point of view. Especially vendors. If Jmv views the ZLD is a clarion, so be it. It’s not my place to give him 20 reasons why its not. I don't mean to offend anyone with my view, but feel strongly we should let moomba owners talk amongst themselves.
Look guys, the 420 is a great unit. It does a lot of nifty stuff. It’s inevitable that the Exile ZLD is going to get compared to it. This is Exile’s solution to zone control. I’ve been involved with product development for god knows how long now--25 years? Let me explain clearly to everyone how things like the ZLD come to reality.... We take a look at whats out on the market, what the high and low points on each product are. Yes we looked at the 420, the Arc XEQ, the Acontrol 3.1, the clarion, and a few others. In every single instance, the story is the same--- It comes down to costs every time. Every feature has a cost. Period. None of these manufacturers lost their marbles and forgot to put something like a microphone in their design. Some manufacturers valued that feature and felt it important to include. Get my drift here? There are pluses and minuses to everything.
Here’s the 411 on the ZLD and why its in there: Our goal was to build something that #1 is easy to use, and #2 is a sound quality piece that wont break the bank. At retail we wanted it positioned not to exceed 200.00. As stated above, every single thing in the box has a cost. So how the heck do we do that. I’ll tell you how, have a lot of damn meetings and evaluate costs/feature sets six ways from sunday. Thats how.
For example, if we eliminated just the Burr Brown sound op amps we could reduce overall product costs by almost 18%. That could afford us some other features. If we didn't opt for big easy to use knobs on the front panel, we could put more features in. If we made the thing a double Din size physically, we could load up with features. In tandem to these product development tasks, we listen carefully to what our beta testers tell us. 4 people in the usa, and 2 people in australia, got the benefit to use prototypes last year. Each of them had a lot input. The consensus is they all valued the highest possible sound quality at the expense of some other advanced features. Every one of them wanted full independent subwoofer control like Mr Mike has mentioned. And Mike - I’m sorry your boat wasn't one of the beta testers. I know you wanted one. I have however appreciated your comments on how you’d utilize it.
Next point I’d like to make and then I’ll get off my high horse, is pre orders. Many people have asked me why anyone in their right mind would discount something brand new. Fair question. This is Exile giving back to all the people that have supported us over the years. There is no way we can really distinguish who is a past exile customer and who's a new one that just wants to get in on a deal. Our intention is to give back to you guys. It’s the first time we’ve done something like this and the response has been phenomenal. Anyone can pre-order from any authorized retailer at the discounted price. This is a USA wide promo only and will end when they begin shipping.
Bottom line: We hope everyone will enjoy this new product from Exile. You have more choices out there for your boat stereo. And thats a good thing.
-Brian
Exile Audio
I personally don't understand why the exile crew is getting so butt hurt. Nothing negative had been said about it!!!
Mike said it had independent volume control when in fact it does not. I believe that is the only controversy thus far? If someone said they like fords independent front suspension id say they must have mistaked it with Chevy.
David chimed in to explain the actually differences as mike said they were very similar.
The poor pitiful me is pathetic especially with the larger following exile has here.
I don't give a sh!! About either brand personally, I just want accurate facts displayed. I think the exile unit will be a huge sell and would consider it myself if I didn't already have an eq, non wetsounds.
Oh, and I guess the microphone thing .. my pet peeve there was seeing someone with a signature like Mike's say they don't know if a mic is a good thing or a bad thing, insinuating it could be a bad thing ... how could it be a bad thing? It's like an aux plug on a head unit. If you don't want it don't use it. I guess it's the tone of the post that have made me reply as often as I have in this thread.
Posts in threads mix facts, opinions and even factual statements that are simply incorrect. Sometimes when a later poster suggests an earlier stated fact may be incorrect the original poster hears either: "I disagree with your opinion because you don't know what you are talking about" or "You're a liar". It seems that was not the intent here at all.
One thing we can all do is try to make sure any statements of fact we make are as true and correct as possible. Another thing we can do is to preface a factual correction with something like, "While I value your opinion, I think you may have misstated a specific fact".
It's hard to just have a beer with someone online like you would on the dock and hash it out. But, I think we can do a better job of having civil discussions without hurting feelings and having people feel like they need to bail on a conversation. I'd much rather have BOTH KG and MMandley involved in the discussion as I value input from them and from everyone else.
All I read of your post was the above and think maybe you should live by your own words.
Your opinion is biased, as would Phil's from Kicker as would Tim's from Wetsounds.
I've enjoyed the technical insights from all the vendors, but we may soon have to revert to the days of no vendors allowed.
To preface Kane's statement, I got just the opposite out of Brian's post, I heard no bias at all. Not because I have Exile and not because I don't like one brand or another. What I got IMO was Brian trying to clear the mystique of what the ZLD does and why they did what they did, period. In fact I didn't read anyhting that touted it above or compared to any other vendors merchandise.
Again IMO I honestly think Brian goes out of his way not to do that when he very easily could. I think the vendors on here are an extremely valuable asset to this forum and without them we'd have way to much misinformation disseminated resulting in botched projects. As an example I took some "gospel" advice from one of our audio experts which was completely wrong and resulted in my having to redo some of my last install. If that can happen then think what'll happen without them. Do we want to be nazis in governing this forum to the point that it hurts all concerned? What we have here is extremely rare, why not use it wisely?
I don't get why everyone is up in arms over this type of stuff. They are here to assist us, not at our personal beck and call I might also add of which I know for fact does happen. I also think that people take crap way to seriously here. Lighten the reins a bit guys, there's no need to start little battles over who-has-what or what-that-does. My opinion is; Who cares? If you need information ask the expert direct, don't start crap here because someones having a bad day, has their panties in a wad or just plain doesn't like someone or their product. All it does is hurt the forum and cause dissention.
Of course all the above is my opinion so take it for what it's worth. And Kane is correct, virtual beers are impossible.
I completly agree with you here man, i was mistaken and once you called it out specifically i went and looked a few more things up and leanred about it. I was miss understanding the tower cabin control as a fade because what i understood was i can lower my tower seperate and my cabin seperate when in fact it fades from tower to cabin. I also might have a couple facts wrong thinking of an earlier revision of the unit.
As for the Mic thing, i can understand you not understanding and or liking me say i dont see the use in it. I guess in my mind, i have never used it, i have never seen it live in a boat, nor have i ever even herd one on the lakes and rivers up here. Yes im sure they are present but never herd any of it. I completly understand your point on its an option and its nice to have those options. I think deep down i just know id end up being one of them that only used it to yell at stupid people on the lake behind us, and end up in a brawl at the dock LOL
I know i get heated at times and passonient at times, thats a good and bad flaw depending on what side of the coin your on with me.
The good thing is i dont hold it against you or let it make me think any less of your thoughts.
As for me when i reach my maximum point of frustration i have 2 options, stand and fight, or walk away and cool off. This is why i said im done in this thread, this is also why i mentioned i dont post in the audio as much, because all i come here for is to help people, learn from people, and share my experiences as most of us do. I used to go toe to toe with an old FL brother but it makes the site look cheap and in the end i would lose since they had a delete button and i dont.
I have the same issue with a vender that frequents here but its due to so often reading posts where in his mind hes helping, and in reality to most hes talking so fare over their head they arnt benefitting from his help. If you just come one here and talk at the level people are asking there questions then it would be so much easier to deal with. When someone asks whats different between X brand and Y brand then tell them what you think is different, not get engineer tech based on them explaining the electrical architecture and materials used to make a product. This gets me heated so fast because people like a simple straight forward answer, not smoke and mirrors of how im smarter then you and im going to throw it out in your face.
I miss some venders that dont frequent any longer for that simple fact. I dont want the venders to leave because as we all have said they help a lot, they clear a lot of things up but just like anything, this site it to help people not wage a brand war.
I do appologize to my Moomba brethern for whats happened here these last couple days, i still love you all and would have a real beer with you all if i was closer to everyone. Its always easier to disagree in person and hash things out as you have live conversation right then and there, not post, wait, repost, wait..
man, lots of man-drama here over a new product :)
I see them both as similar but different and each one has it's pro's and con's.
I'm on the fence as to ordering one as it will fit the bill in my boat as I have NO desire to have a mic in the boat. I see no benefit to it, but I also understand those that do and am glad there is a ws product available that will fit their needs as well. great to live in a country with many choices for something as simple/stupid as this for a boat :)
I agree with what Mike said. I'm an IT consultant and I don't give clients all the details. Vendors are experts in their business, and I look for them to explain to us in 'laymans terms'. Something we can understand and gain knowledge from one product or another for our use.
I'm in the market for an eq. I do like the Exile for the large controls/knobs I see in the pics. I rarely spend time at the cove, as the river is too deep. I'm interested in something I can set my head unit to a volume number, and then force sound between the cabins and tower. It's looking like the Exile fits my needs as I don't foresee myself using a mic frequently.
I got the Krypt one because it was cheap. I wanted the separate tower and in boat speaker control. I got the mike-- might use it, might not. If I do I'll try to annoy everyone around me, especially jetskiers. I would not have paid more than $99 for one of these things though-- any brand.
Holy Chit Storm! I step away for the weekend and this is where this thread went?
There was a pretty good discussion on the product before it was available for order where Brian explained what it was, what it wasn't, and why they did what they did:
https://forum.moomba.com/showthread....=exile+product
Simmer down everybody :) Can't we all just get along?
This forum would be boring if people like you guys didn't get fired up about new products in the marine industry. I think discussions like this are great, especially because I don't think there's any true bad blood here. Keep it up, it's a fun read!
