It seems every year I rebuild the stereo in my Outback, and this year is certainly no exception.
On the list this of things I am doing this year are:
- Build dual battery box (Starboard) & Relocate batteries to where port sub current resides (directly behind bow seat back)
- Relocate port side sub to under drivers dash / build dual sub box for helm (2x Kicker L7 10")
- Build new amp rack for Exile Harpoon, Xi800.4, and Kicker 1000.1
- Instal Exile XM9 tower speakers
- Relocate head unit into glove box (currently mounted under glove box)
There are a few other things I am going to do like adding a relay and larger gauge wire for my in-boat LEDs, install the 2 additional Newty transom LED's I scouped up last fall, and I'm sure more interior LED's.
At any rate, I jumped into the battery box this afternoon. I started by finding a local source for King Starboard and picked up 1/4 sheet (24"x48") of black 3/4". I want to avoid using wood for anything, and since Starboard is what seems to be used for all of the factory panels, I figured it would be perfect for this.
First things first, I needed to devise a plan; at $16/sq ft I didn't want to waste any material!
https://forum.moomba.com/attachment....5&d=1329947750
The start of my box - I used a chalk line to mark my first cut,then went to it with the table saw (I needed 12" and the my tablesaw gate only goes to 11", so I had to free-ball it):
https://forum.moomba.com/attachment....6&d=1329947752
Cut in half, came out pretty clean;
https://forum.moomba.com/attachment....7&d=1329947753
All the cuts made and a mock-up of the box. Basically the lid will sit flush with the 2 longer sides, and on top of the 2 shorter sides. I'm going to use a small square of scrap on the inside of the lid on each end to keep it from sliding back and forth, and some stainless steel latches to hold it in place. I'll cut vents into the sides as well as holes for the wires once I get everything laid out.
https://forum.moomba.com/attachment....4&d=1329947749
I need to pick up some stainless steel screws so I can get it together, I thought I had some but alas they weren't stainless.
Overall the Starboard is pretty easy to work with - I cut it with the same blade I use for MDF and it seemed to do fine, maybe a little harsh, but for this where finished edges don't really matter I'm not worried about it. I'll likely use a router on all of the edges to finish it off, but ideally this will never be seen anyway, as it will be mounted behind the amp rack in the observer side storage compartment.
