Dear Audio Gods! Can you please help?
my kicker 700.5 amp is shutting down & is hot as can be to touch. i'm running a sub off the sub channel & one pair of kicker hlcd's on the other four channels in bridge mode. amp 1 & 2 are set to "Hi" & the sub amp is set to "on/sub". batteries are fully charged.
the manual says this amp will handle this set up, but apparently not. i also have a 200.4 that is running the six cabin speakers. should i swtich the cabin & tower speakers around? can the 200.4 handle the hlcd's?
i read Ed's post where he had similar issues. https://forum.moomba.com/showthread.php?t=14169
any suggestions on what to do to fix would be appreciated. swtich speakers around? replace amps, etc?
thanks!!!
