Anybody know if this will fit our moombas?
http://cgi.ebay.com/ebaymotors/Folle...r#ht_595wt_722
anyone know if the extra diameter would be a problem?
first one ( looks like the moomba wheel) anyone know the manufacturer.
13.78" Wheel Diameter
3/4" Tapered Hub
Aluminum Spoke
second two
14.18" Wheel Diameter
3/4" Tapered Hub
Aluminum Spoke
Bueller???? anyone Bueller:confused:
Go for it, then report back!
Sometimes it's fun to be the guinea pig!
Did you try calling them to ask what it fits?
I think Todd (11OutbackV) replaced his wheel with that blue thing. He may have some insight. The only other one I remember was Sled, but he just went to a Supra wheel so it's the same.
MOST aftermarket steering wheels come w an adapter that should work with what you have. My adapter worked and all I had to get was shorter bolts to make it work. Other than that it was a direct replacement.
Our steering wheels have the marine spline setup, not the automotive taper fit. You'll need a splined adapter to do it, that is as long as the hole pattern on the wheel matches up to the holes on the splined adapter. There are many different hole patterns so make ABSOLUTELY sure the patterns are the same.
Another thing, 14" is a big wheel and when lowered into position might hit your leg, etc. Personally I wouldn't go bigger than 13".
I used the splined factory plate w the adapter that came with the wheel and it worked fine.
Hey Joe,
The Supra wheel is 13.5' diameter. This is the wheel:
http://www.summitracing.com/parts/GRT-457-1/
If you were to go this route, you will also need this hub:
http://www.summitracing.com/parts/GRT-3656-1/
Let us know what you decide on.
Al
Al, that's what I was looking for but came across the others, look pretty cool but as razz said fairly big.
Thanks,
I will let you know.
