Originally Posted by
wakeflip
Ive done nothing but research and price ballast stuff for the past two weeks. IMO, you can go with a Johnson pump, which is identical to the Jabsco pump and just as good, but cheaper. Piece together everything else yourself and you will come out cheaper. You can get the hose pretty cheap at homedepot/lowes, as well as the ball valve. Everything else you can order from wakemakers. If your a moomba owner you get an additional 10% off everything. So, if your going for the cheaper route like I am, piece it together yourself. If your going for simplicity, one order, plug and play, then yeah, its not a bad deal.
