2000 Moomba Outback Died While Running
When we took our boat out at the launch, it started fine... was idling rough but stayed running. Got out on the lake idling, doing ok. But when we tried to speed up a little, the boat died. It wouldn't crank, starter won't turn. Tried jumping the starter to crank, but it wouldn't do anything. Also tried tapping on the starter, but got nothing. The boat is getting gas. Electrical is completely dead. All the gauge positions stayed right were they were at (at running) and wouldn't reset even when boat was shut off. Any ideas what the problem might be? Thank you!
Thank you for all your advice
We have never had any major problems with this boat. Replaced the starter, had to have the packing replaced, and blew a head gasket once, but the head gasket is ok now. It has been an awesome boat. This is the first time anything like this has happened. Can't wait for Spring to break so we can get it back out on the lake again. Thank you all very much for any advice. We will check everything out you suggest.
to all thank you wife is better typist than me,
Quote:
Originally Posted by
cham
Mine will do this if the wires on the back of the ignition switch come loose.
Freaked me out the first time, pushed the wires back onto the contact and everything was good to go.
key switch has moved around tightined once this last summer will make sure wires are tight,thank you .
Thank You For All Your Help!
Sorry it took us so long to reply. We are very thankful for all of the insight from everyone.
We put a new ignition switch in and boat is starting now, but can't get the gauges to reset from where they are at. Tried to unhook battery, but it didn't help. Any suggestions?
