Need Ballast pump and setup recommendations
I could use some guidance on my winter upgrade project.
Planning to run 2 1100 bags in the rear corners of my boat. Each partially full for wakeboarding, or one side at a time full for surfing. I doubt I'll ever be filling both 1100's full at the same time except maybe to see what it looks like at least once!
Would I be better off to share one Tsunami 1200 to fill the rear bags using a splitter and electric switches or just go with two Tsunami 1200's and skip the valves?
As for switches, wiring, plumbing, etc. it will all be custom as basically nothing exists. For the intake I have room and am not afraid to drill another hole in the hull for the additional pump(s). >>I have a Rule pump in there already that will be used to fill my front bag.<<
Cost on this isn't a real big deal but why spend the money, drill the holes, plumb it, wire it, etc. if I don't really have to? Plus I've noticed it seems like the cost of electric valves is almost as much as pumps.
My thoughts are - simpler is better. Oh yeah, and I only wanna do this once!
Advice and experiences would be much appreciated.
This is the Jabsco Pump diagram
Requesting feedback on ballast system layout
So after a bit of head scratching I'm wondering if this type of layout will work?
I'm feeling confident in the setup except possibly for the electric control valve at the end of the system (Irritrol or similar). I'm thinking I'll combine the drain and vent lines together, have them pass through the electric valve, then out the through hull.
When the ballast switch is on "FILL" the fill pump comes on AND the electric valve opens allowing the vent to do it's job. When the ballast switch is off, the valve is closed, keeping the vent or drain line from leaking. When the ballast switch is on "DRAIN" the drain pump comes on and again the electric valve opens.
Simply put, the electric valve opens any time a pump is running. Am I missing anything here? Major no-nos?
This is basically one half of the setup or one side of the boat.
http://i326.photobucket.com/albums/k...last-1side.jpg
