Originally Posted by
outbackv
first of all no i did not run my boat into my garage! and im not replacing the system for no reason and wasting my time nor did i say i want to replace the hydraulic sytem cause it failed!!!!!
the reason why like i said in above post is my plate and hinge are bent not much but it is off set about a 1/2 inch to be exact and makes the boat pull at higher speeds does it absolutely need to be replaced NO but its enough to bug me im 21 and this is my first boat that I ALONE have purchased and want everything working properly...............
my question was since im going to be changing it is does anyone recommend different set ups and if there where pros and cons to different system i thought that what these forums were for
i said nothing about anything FAILING
