In csmsk's excellent heater install write up, he writes,
"Also, I didn't use the three speed control switch that came with the kit. I had a two way rocker switch in the dash that I wasn't using, so I hooked the heater to that. Now I only have control of "high" and "medium" speed. I thought that if I needed the "slow" speed, I didn't really need it on at all!"
I am finally installing a heater in my boat (parts are arriving today) and would like to do exactly the same as Chris did above. I am not very good with wiring so could someone please explain in detail how to wire the heater to the two way rocker switch on the dash, including telling me exactly which wire to attach to which spade on the back of the switch.
Chris, are you out there??
Thanks,
Al
