Originally Posted by
Razzman
Ian i had thought of that as well. There's a couple of problems with that as i see it. I seriously doubt the floor is finished gel coat and every snap in setup i've seen leaves gaps where the floor shows around the carpet, especially on locker doors, etc. So you'd more than likely see black or gray composite floor.
The other issue is that being as the carpet is one piece on the floor and then the upper deck is installed and bolted down you can't easily remove ALL the carpet. So you have to cut it somewhere. Cut around the floor perimeter and you'll see it under the rubber base strip. Cut behind the seat base and you'll have a gap you'll also see.
